Collors problem
Old 07-26-10, 11:59 AM
Unhappy Collors problem
Hello,
Please help with wiring the ceiling fan.
From a fan to a switch goes 4 wires – 1 white; 1 black; 1 red; 1 ground. Power line (I want to tap in) has 2 black; 2 white; 1 red. How do I connect the wires?
Thank you very much.
-Mike
Old 07-26-10, 12:59 PM
Received 1,197 Upvotes on 1,152 Posts
What do you see at the wall switch and how was the previous fixture in this location hooked up?
Old 07-26-10, 01:29 PM
The was an old switch (controls a power outlet with a lamp). I want to replaced it with a new one to control fan and fan’s light (it has 2 separate switches on it). Outlet with lamp should be always ON (I can control it with a witch on a lamp).
Old 07-27-10, 01:42 AM
pcboss's Avatar
Received 167 Upvotes on 146 Posts
You will need to add two black pigtails of wire to the black hots in the switch box to feed the new switches. You will add the white to the white splice. Connect all grounds together. You can add the old red at the switch to the black ho splice. The new black and red will control the fan and light kit.
