old electrical ceiling box
Received 0 Votes
Hello,
I have a 1928 home. I want to put a new light in my dining room. Right now there is a ceiling fan light. I took out the fan. I bought a new hanging chandelier light. I was unable to install it. In the middle of the metal electric box there is like this bolt that goes up toward the ceiling.
This isnt mine but it looks like this, minus the burn marks.
http://www.leoandrene.com/files/gall...card%20430.jpg
So Anyone reading this knows. When installing a hanging light you have a bracket that connect to a screw hole on each side. Then in the middle there is a hole you slide a bolt up and put the nut on top to hold the light.
But I cant because of this stupid bolt in the electrical box.
Does this make sense. Any Ideas? I dont want to have to put a new box in. I fear this box is installed in the plaster and lathe and removing would create a whole new box of worms.
Are there any attachements you can buy or different brackets?
thanks
Jake
thanks
Jake
Honestly my first thought would be to replace the box. Some questions first. Is there an accessible unfinished attic above? Is you wiring knob and tube (K&T). that is individual cloth covered wires or conduit, or cable?
Received 0 Votes
Yes, there is an accessible unfinished attic.
I dont know for sure but I think it is cable wiring. I am a new homeowner, but I am pretty sure it is insulated plastic over like a copper looking wire.
thanks
thanks
Is it possible the bolt looking thing is an old gas line for gas lights
Looking in the attic and telling us what's there, confirming if you have cable and some actual pictures of what you have would be helpful.
Received 0 Votes
It is about an inch deep box that looks just like the one in the picture except there is also like a bracket/rod that runs acoss thrugh the middle of the box and it also goes through the mounting bracket nipple thingy. it supported a ceiling fan just fine.
If I do put a new box in I suppose I have to get to it through the top in the attic???
I have a concern that the box may be fastened to a joist. There is a workaround if it is. First though I'd try to remove the brackets fastened to the box including the nipple. If you can remove the hangers you may be able to reuse the box. If there is any way you can post actual pictures of the box it might be very helpful.
Last question for now, is the box diameter 3" or 4"?
