Unsuccessful installing dimmer switch
Old 11-15-10, 02:34 PM
I can't figure out why the dimmer switch I installed won't work. The lights don't even come on. I put back the old switch, and it still works.
The dimmer is for the ceiling flood lights in my kitchen. I replaced the incandescent bulbs with dimmable flourescent bulbs. I twised the wires from thje dimmer around the wall wires--both the black wires and the ground--but still no dice.
Any thoughts?
Old 11-15-10, 02:55 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Even though you have dimable fluorescent bulbs the dimmer may not be compatible with dimable fluorescents. Is it? Give us make and model number and perhaps someone here will know.
Old 11-15-10, 05:50 PM
Tolyn Ironhand's Avatar
Received 60 Votes on 53 Posts
You might have a bad dimmer. It has been known to happen.
Old 11-15-10, 06:09 PM
model numbers
Thanks for your reply. The model numbers are
Dimmer: Leviton,Trimatron, 120VAC, 60Hz .
Bulbs: TCP nodel 2R4019DIM, 2700K, 120V, 60 Hz, 19W, 0.176A R40
