connecting switch with pilot light
Received 0 Votes
Hi all, new guy here. I have a Leviton switch with a pilot light, #5226-isp, (to indicate that the subject lights are on), and am a bit confused by the provided wiring diagram. It seems to indicate that a jumper is needed on the 'line' side for the lamp. I checked continuity w/o the jumper, and the switch works ok but the lamp terminals are, seemingly, unaffected by switch position, with or w/o the jumper.
Any thoughts?
Any thoughts?
So that is to say that they don't work in a switch loop? I got one in a two way setup that required no special wiring at all for the pilot lamp in the toggle to work only when the subject light is off. Maybe single poles are different.
Switch
When using a switch loop and a neutral is required, use a 3-wire cable to connect the neutral on the switch to the neutral in the ceiling box.
When power is fed into the switch box and a neutral is needed, use a jumper to connect the neutral to the switch.
Is this the wiring diagram you have? :
Leviton Online Knowledgebase: 5226 5626 Instruction Sheet.pdf
If so, look at page 2.
Received 0 Votes
Thanks for the link. I find it interesting that the leviton faq site did not appear during a fairly exhaustive web search...
The schematic (PK 93474-10-00 Rev A/1) supplied with my switch is different but along with the link dwg I am able to determine that I will be unable to use this #5226 as I had wanted due to the lack of a neutral leg.
Many Thanks.
Many Thanks.
