recessed lighting installation
Old 12-17-10, 02:36 PM
O
I'm in the process of installing recessed lighting in the kitchen. I'm replacing the recessed flouresent tube lighting with recessed can lights. As shown in the picture, the exsisting light bays are covered with drywall. Is is ok install the the recessed light in here with no issues? Should I just put insulation up in there before i put the new drywall in? I bought the Halo recessed light for installed into insulated areas.
Old 12-17-10, 03:10 PM
pcboss's Avatar
Received 43 Votes on 38 Posts
Is an attic above this area or is it the framing for the second floor? i would only worry about insulation if this was under an attic.
Old 12-17-10, 11:54 PM
O
There is an attic above this area. It is insulated above drywall inset. I guess I was more worried about fire issues, but I guess with the one for insulated ceilings it shouldnt be a problem with nothing around it.
Old 12-18-10, 01:53 PM
Tolyn Ironhand's Avatar
Received 93 Votes on 83 Posts
You are fine with your plan.
Old 12-19-10, 01:27 AM
O
thank you all for your help
