Problem with bathroom fan
Received 0 Votes
I am trying to install a new bathroom exhaust fan however I am having a difficult time getting power to it. I ran the fan wiring down the the light switch box that controls the 1 light fixture in the room. The problem is that it is an end of the circuit switch (only 1 wire going into the box from the light fixture). Is there a way to pull power from this to run the fan either on the same switch or a second switch?
One way to do this is to replace the 2-conductor cable from the light to the switch with a 3-conductor cable. If you have an unfinished attic above this will probably be no harder then running the two conductor from the fan to the switch..
Received 0 Votes
Well yes...I have one cable running into the box, which does not contain a ground. Is there another option besides re-running wire, as the upper level of the house is finished?
You could come off a receptacle if it is grounded but ungrounded circuits can't be extended. How did you get the fan cable to the switch? How are you venting the fan if the area above is finished?
