Wiring an outlet into an end-of-circuit switch loop
Received 0 Votes
I am attempting to wire a GFCI into an end-of-circuit switch loop. I know it is an end-of-circuit as I only have 1 feed coming into the box (normal romax with 1black,1white,ground). I have tried a few different combinations of wiring and the best I can get is the outlet to be "ON" with the switch is "OFF". Once I turn the swith "ON" power to the oulet turns "OFF". Can someone help me wire this correctly? I want either the outlet to be constantly powered or at least "ON" when the light switch is "ON". Thank you! Using a Levition outlet.
Tech note: Proper procedure when this circuit was run was to recolor the white wire black or red or some other color except green or gray but that often isn't done.
