My new light keeps going out.
Received 0 Votes
Hello everyone,
I have a problem. I put up a new light fixture in my kitchen with two light bulbs. They both go on for about 15 minutes then the same one goes out, it doesn't burn out it just goes out. I shut it off for a few minutes, turn it back on, then 10-15 minutes later it goes out again.
Any ideas?
Any ideas?
Welcome to the forums!! You have too large a bulb in the fixture, and it is heating up. The over heating protection is doing it's job. Reduce your bulb size or use a CFL to avoid the nusiance trips of the device.
you told the first O.P. it was the overheat protection but he doesent have can lights. he has a fixture with two light bulbs. what kind of can has two lights in it?
The previous fix applied only to can lights. If this is a new fixture I'd suggest returning it. If you don't wish to return it my first suggestion would be to bend the tab in the bottom of the socket up a bit. Turn off the breaker before doing this. If that doesn't help pull the fixtures and redo the connections. If you used the wirenuts that came with the light check if they are real or fake. A lot of the imports have fake wire nuts. Real wirenuts have a spring inside. Replace with real wire nuts if there is no spring inside.
