Utilitech 120v 6-light Xenon 3-Level Touch Dimmer
Received 0 Votes
Fuse has burned out repeatedly in different dimmers. Other than buying another kit, is there a source for the dimmer module?
Can you access the fuse and is it replaceable? Fuses will have a rating on the barrel (the metal ring on the ends) someplace although it may be quite hard to see.
If you are blowing fuses you are overloading the dimmer.
Received 0 Votes
Temporary Solution
I have replaced the fuse with a 3A 250v fuse which has a larger diameter end cap than the one which failed.
Some fuses are installed in a clip soldered to the circuit board. Most seem to have a very tight metal cap at each end which is soldered to the board.
I was able to solder a replacement fuse to the circuit board directly, and it works.
There are only five puck lignts on this dimmer.
Received 0 Votes
I see other brands of dimmers available, as I was stumped by my Utilitech dimmer not working.
Thanks for this thread. Had no idea that the dimmer module on my 6 light Utilitech unit had a circuit board and FUSE. Getting the 3 amp fuse out was a bit tricky, but, replacement will be easy as soon as I get out and purchase one.
Cheers from May-hee-ko!
