Ceiling fan and roof pitch--54 in. OK with 6 in. drop rod?
Old 02-28-11, 07:40 PM
K
Question Ceiling fan and roof pitch--54 in. OK with 6 in. drop rod?
I have a new home that I am purchasing ceiling fans for. The ceiling has a 3.5 pitch. With a 6 in. drop rod, am I OK with fans with 52-54 in. blade span? Or do I need to stick with 44-48 in. (which are hard to find these days)?
Secondly, if possible, can someone provide the math? I've read that a 3.5 pitch is a 14 degree angle, but I don't know if the source is reliable or not.
Old 02-28-11, 08:13 PM
bish80's Avatar
How high is the ceiling? If the ceiling is 9 or 10 feet I would like a longer drop due to better air circulation. The fan gets more ineffective the closer it gets to the ceiling.
Roof Pitch Table
1 12 4.76°
2 12 9.46°
3 12 14.04°
4 12 18.43°
5 12 22.62°
6 12 26.57°
7 12 30.26°
8 12 33.69°
9 12 36.87°
10 12 39.81°
11 12 42.51°
12 12 45°
Old 03-01-11, 06:44 AM
W
Received 22 Votes on 21 Posts
Math
12/3.5=3.43
6" x 3.43 = 20.58"
Add to the 6" down rod the height of the hood and do the calculation on the line above to get the allowable horizontal distance from the center line of the fan to the end of the blades.
Old 03-01-11, 07:46 AM
K
Nine feet to the ceiling for the lower of the two (10 feet for the other). A 6 in. drop leaves the fan bottom 7 feet 7 in. above the floor. To drop another six feet will bring it to just about seven feet.
Roof Pitch Table
1 12 4.76°
2 12 9.46°
3 12 14.04°
4 12 18.43°
5 12 22.62°
6 12 26.57°
7 12 30.26°
8 12 33.69°
9 12 36.87°
10 12 39.81°
11 12 42.51°
12 12 45°
Old 03-01-11, 09:11 PM
bish80's Avatar
Does the ceiling come to a point or is it flat on the top like a trapezoid and if so, what is the measurement of the top side. If it is a trapezoid, you will need that info to use Wirepuller38's calculation.
Old 03-01-11, 10:09 PM
K
Shed roof
It's a large shed roof. No point, no apex.
