In Wall Night Light w/ motion sensor
Old 03-31-11, 03:15 PM
When they built our house I had them pre-wire 4 outlets so could install lighting at a later date.
The are pre-wires are on the wall along the stairs and 2 are in the hallway. All are about 1 ft off the ground are cutout with a dummy outlet plate over them.
What am looking for is a lighting product that would fit in a standard wallbox and provides indirect lighting , LED, has some sort of timer (dusk/Dawn/Timer,etc.)
A big plus would be a motion sensor.
I wanted to see if anyone can recommend a product or brand?
Here is one i have found that seem to fit the bill but doesnt have motion sensing which I would really like to have.
Amazon.com: Designers Edge L-7010 In Wall Dusk to Dawn LED Nightlight: Home Improvement
Thanks for any suggestion :
Old 03-31-11, 08:53 PM
lawrosa's Avatar
Super Moderator
Received 25 Votes on 23 Posts
I like the louvered ones. I dont know why you would want a motion detector. Possibly its always dark in the hall and they will always be on?
I would try to add this at a wall switch but you may need to do some wiring.
WSD - Motion Detector Switch
They do make one though. I found this.
Leviton DecoraŽ Occupancy Sensor Wall Switch with LED Night light
Mike NJ
Old 04-01-11, 07:10 AM
scoob8000's Avatar
FWIW I have one of these in my bathroom and it does the trick nicely.
It has a photocell in it, so the nightlight is only on when needed. It's also bright enough to do most of your business in the dark.
LED's have such a long lifespan, and use cents per year to operate I wouldn't worry about having it on a motion sensor.
If you don't want the gfci, they have a straight night light model too.
FWIW on power consumption, I have a few plug in led night lights that dont even register on my kill-a-watt..
