ceiling fan works but not the light
Old 05-03-11, 11:04 AM
i ahd a ceiling fan with light operated by 2 wall switches which worked fine. the new fan works but not the light. I connected white to white green to green black to black and blue to red. on the light attachment i plug the plastic piece from light to fan motor as instructed. help for the light?
Old 05-03-11, 11:21 AM
Received 4 Votes on 4 Posts
Fan
Connect the new fan and light the same way as the old fan and light.
Old 05-03-11, 11:31 AM
i did that first and it didn't work. that connection was blue to black, black to red white to white green to green;so i switched to new configuration which made the fan operable from the other wall switch but no light. both configurations allow the fan to operate but not the light.
Old 05-03-11, 12:55 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Check for continuity from the white at the top of the fan to the neutral side of the light plug then check for continuity from the blue wire at the top to the hot side of the light plug.
Old 05-03-11, 06:49 PM
Tolyn Ironhand's Avatar
Received 59 Votes on 52 Posts
Dumb question: Did you turn on the light with the pull chain first before trying the wall switch?
Old 05-07-11, 08:02 PM
Justin Smith's Avatar
Do you have just plain switches or some sort of control?
