Replacing a recessed halogen socket
Old 05-14-11, 12:07 PM
Hi, in trying to replace a burned-out halogen bulb, I saw that one of the holes in the bi-pin socket has enlarged to the point that the bulb won't stay in securely. Therefore I figure I have to replace the socket. But I can't figure out how to get it out. I've posted a picture. You can see that there's a metal plate attached to the plastic socket via two holes (the two right above the holes for the halogen pins). They're not screws, and I can't figure out how to get that metal plate off so that I can get to the socket.
Any ideas? Once I get the plate off, am I right that I can remove the socket from the wiring and take it to Home Depot to get a new socket?
Thanks!
Old 05-14-11, 01:44 PM
ray2047's Avatar
Welcome to the forums. Your link must be on a public site. Your link is to a private site that denies access. You could use Photobucket or Imageshack.
Old 05-14-11, 04:03 PM
Thank you, I hadn't realized that access was denied! Let's try this:
Old 05-14-11, 04:11 PM
ray2047's Avatar
Is this a recessed light fixture? Are you sure you can even get a replacement socket?
Old 05-14-11, 04:36 PM
It is recessed. Are you usually not able to replace those? They were installed by the previous owners of our condo.
If I can't replace it, is there anything I can do to shore up that hole on the right that's so loose?
Old 05-14-11, 05:05 PM
ray2047's Avatar
I'd just replace the fixture.
Old 05-14-11, 09:07 PM
Thanks for helping; I guess I'm not sure what I'd be replacing... the wire comes from the ceiling and goes right to that assembly that I've pictured. I probably don't know enough yet to ask the right questions.
Old 05-15-11, 05:45 AM
ray2047's Avatar
Can you step back with the camera and give us a more general picture of what you have. I can't tell what kind of fixture you have from the photo.
Old 05-21-11, 12:01 PM
CasualJoe's Avatar
Received 178 Upvotes on 161 Posts
That looks like a MR 16 socket. There are several available and you can probably find the right one online. On a quick Google search this is the first one I found.
Amazon.com: MR16 MR11 LED Light Socket,2008: Home Improvement
Here's another
Satco 90-475 75W-125V MR16 Socket GX5.3 Base Porcelain Halogen Socket
