Dimmer Switch overheating
Received 0 Votes
I recently installed a 1000w dimmer switch and it get so hot (125 deg) that it burns to the touch. I broke off all side tabs and according to the manufacture that will reduce the wattage to 650w. The switch controls (9) 65w bulbs (total wattage 585w). I am at 90% of the manufactures recommended wattage and the switch reaches 125 deg after an hour and half; which was a temp increase of 59deg.
I believe that the switch is faulty, but at $40 a switch I do not want to go and buy a new one and still have the same problem. Any input would be great. Thanks
Why did you break off the tabs?
This is from the Lutron website.
Why do dimmers get warm, and is this safe?
The technical explanation: During normal operation, solid-state dimmers generate heat. A solid-state dimmer is roughly 98% efficient – 2% of the power is dissipated as heat, which causes the dimmer to feel warm to the touch. The closer a dimmer is run to full output and the higher the load (watts) on the dimmer, the warmer it will feel.
This is perfectly normal and safe. Lutron dimmers are designed to the strictest UL safety standard, and can handle their full rated load (a 600 W dimmer can handle a full 600 W of power* without overheating.
[SIZE=1]*Dimmers that are ganged together in a common wallbox may need to be derated. [/SIZE]
I broke off the tabs because there is another dimmer and switch in the box also.
Received 0 Votes
I would think that the switch running the in 1000w position to provide 585w would run cooler than having it it run nearly full out in the 600W position. I generally try not to exceed 80% of max rating.
Maybe a test can be unscrew a handful of bulbs and see if it still gets that hot, if so could point to a defect in the dimmer ?
Is it possible to swap out your bulbs with the cfl type, it'll greatly reduce your wattage and maybe cool things down.
