Bathroom Fan Wiring Issue
OK, I installed a bathroom vent fan in one of my bathrooms & it worked fine. I installed a double switch assembly in place of the original single light switch & used one for the existing light & the 2nd for the new fan. I used the same hot to power both devices & used a common that had been pulled to the box. This worked perfectly.
Well, I installed another one like this in a different bathroom only a common wasn't pulled to the switch box. I used the same hot to feed the switch for both the existing light & the new fan but had to grab common up in the box above the light. The fan runs just fine & the switch works just fine.... unless the light gets turned out. The fan will run ONLY if the light is on. I don't get it.... common is common, the power switch to the light shouldn't affect this....
Any thoughts?
Texas Fire
Any thoughts?
Texas Fire
Can you better describe your wiring and the connections you made?
All conductors of the circuit should be run together. You risk overloading the neutral if you grabbed a neutral from another circuit.
This seemed like a no-brainer.... I had a hot wire feeding a single switch that turned a bathroom light on & off. I swapped the single switch for a double with the intent to use the same hot for both the existing light & newly added fan. I don't see any reason why the neutral for the light circuit couldn't be the neutral for the fan. The light box was only about 2 feet from where the fan was installed. I grabbled the neutral in the light junction box, the white wire going to the light & tied my fan neutral in there. Like I said, works GREAT as long as the light is on. Once I kill the light the fan goes out. Doesn't make sense.... I'm only killing the hot, the neutral for the fan should be "unbroken".... I'm not grabbing just any neutral, its the one for the same circuit & I doubt I'm really overloading anything as the fan doesn't have all that much draw...
TexasFire
The hot was at the switch box, the same black hot wire that was feeding the light. My replacement dual switch allowed the option of separating hots or using a common hot feed to switch two outputs. That's the way I chose.....
TexasFire
TexasFire
Aww... you know I assumed that the black wire was the hot on the switch loop but maybe it wasn't. I didn't check it to ground as I had the power off while I had it apart. I will go back & check that. I'm guessing by your comments that it would matter.....
TexasFire
TexasFire
