OK to use larger CFL bulb than incandescent?
Is it OK to use a larger CFL equivalent bulb than the specified incandescent bulb?
For example, if the fixture says to use max 60w incandescent, can I use a 75w or even 100w CFL equivalent bulb? Either of those will still use much less than 60w, but not sure if it would be OK. Obviously don't want to create a fire hazard. Just looking for a way to get a little more lumens if possible. Thanks.
You're not using a larger bulb - the equivalency is relating to light output, not power consumption.
My opinion, the equivalencies are not accurate, I always go up at least one notch because I find the CFL to not be as bright as the equivalent incandescent. Thus, in your case, I'd maybe go up two notches - if you're replacing 60w incandescents and want more light, I'd go with 100w equivalent CFLs (which actually use 26 watts, IIRC).
I use them anywhere I can..and I always use the bright white (daylight?) almost blue light bulbs. Too much time spent in the Navy working in bright fluorescents I guess. Soft white incandescents and such are just way too yellow for me.
