Need help in finding 3" recessed light housing for 1 1/8" inch ceiling thickness
I will cut to the chase. For our ceiling, we are installing a 5/8" dry wall, together with 1/2" soundproofing. This gives our ceiling a total of 1 1/8" thickness.
It turns out that the Eurofase 3" housing that I was going to use is not compatible with anything beyond the standard 5/8" thinkness. Basically, you cannot set the trim properly and it will not snap-in.
After doing much research, I can only find one brand/model which is adjustable for ceiling thickness of 1/2" up to 1 1/2". It is Halo H36TAT. It is sold at Home Depot and I have heard unkind things about the long-term quality of this device.
Can anyone recommend any other brand (model) options that would allow for 1 1/8" thickness to work? My wife and I definately want to have the soundproof later installed. We will be using 50-watt GU10 line-voltage lights and NEW housings.
Thank you in advance for your input / advice.
The light unit will sit flush to the sheetrock, so there should be no problem for the trim sitting flush. How are they mounted? Are they old work or new boxes? Is it accessible from above?
