Trick for hanging pendants at exact same height?
Old 09-30-11, 10:45 AM
I'm hanging 3 pendant lights and of course I will measure but chances are they will still be slightly off. Is there a trick for getting them at the exact same height?
Thanks
Old 09-30-11, 10:54 AM
ray2047's Avatar
Received 15 Votes on 13 Posts
Old way a string line; new way laser transit.
Old 09-30-11, 10:56 AM
Tolyn Ironhand's Avatar
Received 551 Votes on 473 Posts
Unless they are quite a bit off (more then 1/4") they will look the same height. No need to be 100% exact.
Otherwise a real handy tool is to use a laser line. If you don'e access to one, then extend a steel tape measure and lock it in place. Set it to the height and set it on it back so the tape is standing up. Use that for your guide.
Old 09-30-11, 11:08 AM
thanks for the tips. those will help. what about tying the pendant cord into a knot on the inside of the cover plate at the exact height?
Old 09-30-11, 06:25 PM
Does the pendant only hang from the cord? Most ones I have installed either have a chain, cable or rod.
Old 09-30-11, 07:41 PM
just a cord; chain and rod would be easy to get at the same height i would think
Old 09-30-11, 07:45 PM
pcboss's Avatar
Received 141 Votes on 125 Posts
I have hung some that had a compression grommet that you could loosen and extend or shorten to get the correct height and than tighten the gland.
Old 09-30-11, 07:52 PM
but that's only if the fixture comes it with it or you just added a grommet?
Old 09-30-11, 08:14 PM
ray2047's Avatar
Also check the distance from floor to ceiling at each pendant. Yes, in a perfect world they would be the same but often they aren't. You may have to put them where they look right. In this case that would probably mean measuring from the ceiling but sometimes you have to use a fudge factor to get it to look right to a casual glance.
Old 10-01-11, 08:25 AM
pcboss's Avatar
The glands came on the fixture.
