Installing ceiling fans from scratch
Received 0 Votes
I just brought a house that does not have ceiling fans in any of the rooms. So this oversight has made it to the top of my honey-do list. I have everything pretty much ready to go for the installation of the fan. But I have a question. I had to rewire the outlets that the switch controlled, and then use the switch to control the soon to be installed fan. I did everything at the outlet correctly according to the socket checker thingy. However, there was a red wire that is no longer getting used, that I capped off. I understand that usually the red wire is the switched " hot" wire.
When wiring the switch there was a 3-wire and a 2-wire in the box. And i fished in a 2-wire, making a total of three cables in the box. The way that I wired it (on a single pole switch) was attaching one black wire to the bottom screw, pig tailing the two remaining black wires to a small black wire whose other end went to the top screw. The three white wires were capped together, and the three grounds were capped with an additional ground that went to the ground screw (total of 4 capped wires). This left the red wire...my thinking is that this is the same red wire that I capped at the outlet, and so I capped this end.
Other ways that I tried, always left the outer lights off, this way everything seems to be working correctly, I just don't want anything to happen down the line. Can anyone tell me if I did the correct thing?
Welcome to the forums! Cap off the red wire on both ends if it is not being used. Did you replace the receptacle and does it work as you wanted, either with or without switch control? In the ceiling did you install a fan rated box?
If your on 2011 code, you are required to pull a 3 wire (14/3 12/3) cable to a ceiling fan. Also, since you have eliminated the switched outlet you are required, by code, to install a light kit. All rooms are required to have a switched lighting outlet. (someplace to turn on a light via the wall switch.)
Everything else you have done sounds correct.
Received 0 Votes
Thanks for the swift replies. The ceiling fan does include a light kit. And the switch does work the way I want it to for now, as I have yet to actually install the fan, but power is going to the cable.
Received 0 Votes
Ok, thanks for the help previously to all who replied. I'm now on my third ceiling fan with light kit. I have everything installed, yet it's not working. The first two that I installed both work fine, however they were the exact same fan. This one however,mis different. This one has a remote, so it has a transmitter. I am 99% sure that I have everything hooked up right. I have double, triple checked the wiring and everything is according to the directions. There is power going from the switch, and power going to the fan, and lights, yet nothing is working. I was so adamant that everything was right, that the one currently installed is actually the second one, just I case the first one was faulty. I've also changed the switch out. Are there any common mistakes that I may be overlooking?
Received 0 Votes
There are two sets of wires in the switch box, one comes from the outlet that I re-wired, and the other I fished in there and goes to the fan. The outlet tester tells me that I wired it correctly. At the fan there is the 14/2 wire I fished in which is attached to the receiver. Transmitter and receiver are on the same frequency.
I did find a new problem. There are outlets in my bathroom that are not working. And it doesn't look like any circuit breaker is tripped. Also the outlets aren't ones that I had turned off while working.
Is there a speed control (pull chain) built into the fan? Try putting that on high if the remote is on high already. If you have a speed control or dimmer at the switch box change to a regular switch.
Every remote I have installed on a ceiling fan wanted the fan set to high before the remote was installed. If not the default high speed will be whatever the fan was set to.
Received 0 Votes
I don't see anywhere that says what voltage it is, so I would assume its 120v as it does specify indoor use. If it helps it is a hampton bay, Cherokee, 56" fan w/ light kit.
Removing the bulbs doesn't make the blades move either. I thought that they were moving previously, ever so slightly, but there is no movement now. I can still hear the motor trying to work, and clicking from speed to speed when selected.
At the ceiling you did connect the blue and black fan wires together didn't you. You need to recheck that connection.
Final thought. Many fans come with "fake" wire nuts. The wirenuts have no spring inside. If the wire nuts you used have no spring inside replace with real wire nuts.
Of course it could just be a bad fan.
Received 0 Votes
It was a loose wire in the wire bundle that connects to the light kit. One of the wire pins had been pushed back or something. All is good now. Thank you to all for your help.
