How to wire bath fan/light combo in remodel
Old 11-05-11, 06:46 AM
G
This fan/light/nightlight unit can be installed with a 3-toggle "multi control." The wiring instructions show this.
[IMG] Uploaded with ImageShack.us[/IMG]
But I just want my existing wall switch to turn on the fan and light part of it. Nothing fancy.
My existing wiring is just 2-wire with ground.
Can I just use a single wirenut to connect my existing black wire to the black wire for the fan and the blue wire for the light?
Then use a single wirenut to connect my existing white wire to the white wire for the fan and the white wire for the light?
Then connect the ground wire to the green screw?
Thanks!! Gary
Old 11-05-11, 06:53 AM
Gunguy45's Avatar
Super Moderator
Received 3 Votes on 3 Posts
Yes you can do as you describe...but you won't have a nightlight function.
Old 11-05-11, 07:32 AM
W
Received 19 Votes on 18 Posts
Switch
And the fan and light will be on at the same time or off at the same time.
Old 11-06-11, 06:21 AM
G
Thanks
Just the info I needed.
Many thanks. Gary
