Another bulb replacement problem
Old 11-20-11, 02:26 PM
My home was built in 1975 and used very up to date fixtures. Unfortunately the light in the bathroom ceiling flush-fitting light/fan/heater has burned out. This is the first time I have run across this particular problem as I have only recently acquired the family home. I cannot figure out how to get to the bulb. I have tried the lift and turn technique but there is no indication that it is going to move. I tried taking pictures but too little light ( ) so I used the pencil and paper method and found out that the glass has the work Nutone on it in raised letters. Any suggestions?
Joe
Old 11-20-11, 02:47 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Try grabbing the outer edges of the metal trim and pull down. You may need to run a thin blade between the trim and ceiling if it has been painted in place.
