Cold water pipe in my way of electrical box
Old 11-20-11, 05:32 PM
P
I am having an issue replacing an old vanity light. There wasn't a box behind the old light and normally I would just install an old work box but the cold water pipe runs right through the middle! What are my options? Any help is appreciated!
Old 11-20-11, 05:46 PM
Tolyn Ironhand's Avatar
Received 551 Votes on 473 Posts
You could use a pancake box. They are only 1/2" Deep. You will need to run a board (or plywood) behind it in the wall so you have something to attach it to.
Old 11-20-11, 05:59 PM
pcboss's Avatar
Received 141 Votes on 125 Posts
Some fixtures do not require a box. The housing itself is the box.
Can you post a pic of the fixture?
Old 11-20-11, 06:06 PM
ray2047's Avatar
Received 15 Votes on 13 Posts
Just curios are you sure it is the cold water pipe and not the vent pipe. Is it about 2" in diameter?
Old 11-20-11, 07:35 PM
P
it's deff a copper pipe going to the cold water for the bathroom sink. that is the old fixture in the picture...
I'm trying to install this light:
Shop Portfolio 4-Light Brushed Nickel Bathroom Vanity Light at Lowes.com
Old 11-21-11, 05:27 AM
pcboss's Avatar
Your new fixture will require a box. I think the pancake box is the way to go. You should be able to fit a furring strip in front of the pipe to secure the box to.
Old 11-21-11, 06:28 AM
P
Thanks alot.... What's a furring strip?
What's the best way to attach it looking at my picture?
Old 11-21-11, 07:34 AM
ray2047's Avatar
Furring strip is just a board really. Cut out a strip of Sheetrock between the studs. Install a 1X4 flush with the studs. A 1X4 may be too thick. If so use a strip of 1/2" or 3/8" plywood. Install new Sheetrock over the furring strip with a precut hole for the pancake box.
Fasten the furring strip to blocks screwed to the inside of the studs.
Old 11-21-11, 09:39 AM
P
I should be able to handle that.... Thanks!
Old 12-06-11, 09:37 AM
P
I used a 3/8 piece of pine with a 1/2 box , patch the drywall, looks great thanks!
Old 12-07-11, 07:15 AM
pcboss's Avatar
Thanks for the feedback. Glad to know it worked out for you.
