cons of ceiling fan in kitchen? grounding issue with body
#43
There appears to be the ground from the cable attached to a screw just to the left of the open knockout. I too think the problem is an open splice, perhaps in the switch box.
#44
quick question..didnt get to the box yet but the line still runs from the ballast to the ground in the utility room...
however the light wont start up all the time now. if you wait a few min it will turn on though
the question is: even i fthe ground in the switches are bad, sholdnt the light light up right away with the direct wire to my box?
#46
to end this saga i got this
Shop allen + roth White Acrylic Ceiling Fluorescent Light at Lowes.com
i had another one picked out online in clearance but no stores had it..i dont konw why they even advertise it then..sigh...so went and just got this one..t8 68 watts surprised me..it's pretty much as bright as the 6 standard 20 watters in the old fixture
the old fixture was very heavy and cumbersome to take down..was held up by toggle bolts and i reused 2 of the holes on the new light and new toggles on 3 of the holes..i hate those cheapo anchors the include with the kit..do you want your life hanging in the balance of them? not me
i also discovered that about 6 inches away from the current line from the ceiling was the actual ceiling box..apparently when they went from a tiny circular light to a large square one it couldnt fit between the beams..so they ran a wire over a few inches...i also saw the ground from the new wire was screwed onto the electrical box itself..i took it off there and hooked it up to the other groundwire in the box directly.
and there was one other wire in that box so it feeds somewhere else.just not sure lol..but doesnt matter..it all works, it's definitely secure with oversized toggles and it works 100% of the time ..what more could i ask
i momentarily thought about hanging th elight in the utility room or garage but didnt want to hang up a known poorly working fixture..the spring cleanup guys that drive around in pickup trucks can have it
#47
I'm glad you got it working, but I do see one remaining question.
When you say
are you saying that you found a covered J-box in the ceiling with splices in it and that, after reworking the ground connection there, you left it in the ceiling?
If so, how are you planning to bring that into compliance with the code?
When you say
