Help! My dog ate the battery holder!
Old 12-02-11, 06:42 AM
T
I have a set of miniature battery operated street lights for my Christmas village. The batter case ( and on-off switch) fell, pulling out the wires and my dog ate the case. All I have left are the wires hanging down. Is there any way to fix it? I have a small soldering iron.
Thanks!
Old 12-02-11, 07:02 AM
P
Received 632 Votes on 584 Posts
You can buy battery holders at many online electronics or pinball supply stores. You should also be able to find them at a Radio Shack. Do you remember how many cells your decorations took? Buy a battery holder with the same number of cells and connect your wires. If you want to get fancy you can put an on/off switch in the line so you don't have to pull the batteries to turn it on/off.
Old 12-02-11, 08:16 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
I'd suggest a DC wall wart (plug in power supply. If you don't know the voltage of the village get an adjustable PS and start with the lowest voltage and if the bulbs are dim go up one step. If you had only two batteries my guess would be 3v.
