HAMPTON BAY wiring info needed
Old 01-09-12, 12:12 PM
A
I have a hampton bay ceiling fan that works no problem has a wall switch with low medium and high I am installing a light kit for it the kit has two lights with 2 black and 2 white wires the fan has one blue and one white both marked lights what ones do I connect to what and do I need a different switch I dont see anywhere on the switch to just turn the light on by itself
Old 01-09-12, 01:28 PM
ray2047's Avatar
The two blacks to the blue and the whites to the white. That's the easy part.
You need to drop the canopy and see if the blue wire is attached and if so where. You need to see if there is a red wire at the junction box under the canopy. If so you need to check the switch to make sure the red wire is there. Tell us all the wires under the canopy at the ceiling box and in the switch box and if connected to what.
