Another Ballast replacement ...T5
Received 0 Votes
Since we are on the topic of ballast wiring I thought I would ask mine too. I have a High Output T5 light fixture that needs a new ballast. I purchased a lightolier controls HDF239T5 for the replacement. Now my fixture and burnt original ballast are not dimmable, but apparently the ballast I purchased is. It is a three wire setup with a white, black and tan(dimmer).
Everything is all wired up except the dimmer wire and go figure it does not light the lamp. My question is what do I need to do with the dimmer wire to let the ballast know it needs to run at full power? My thought is to wire it in with either the white or the black wire, but I am not sure which or if this will tell the ballast to run at full power. THANK YOU ALL FOR THE HELP!!
It does not look like you need the tan wire connected.
Product Catalog Datasheets - Fluorescent - Philips Lighting Electronics
Does your wiring match the diagram on the ballast or in the PDF?
Received 0 Votes
Ok, so here is what the light is doing ... one bulb flickers, then pops on for a second and then goes dark. The other bulb does absolutely nothing. I rechecked all of the wires and connections with the diagrams and it all look correct. The only area that could be an issue would be where I connect in with the yellow wires. What I did was simply cut the old ballast wires (blue and red), took one blue and one red spliced them and then connected them to one of the yellow wires. I then did the same for the other pair and yellow wire. I don't see plus or minus's, so I assume how I connect them won't really matter.
