1 Light Goes On 2 Go Off
Received 0 Votes
Hi, I recently replaced a light switch in one of my room and for some reason every time I turn it off the power and lights in 2 other rooms go off but when I turn the switch off the 2 rooms are fine until I hit the switch and its like the power is sucked outta them. Did I do something wrong?
Troy
Troy
A 3-way switch will have three screws on the sides of the switch (2 brass and one odd color) not counting the ground screw (green) A single pole only has 2 screws. If you were replacing a 3 way with a 3 way there should have been 3 wires to it not counting the ground.
As Scott asked, did you replace wire for wire on the new switch? IMO you have mixed up the wiring and are switching a feeder leg to the other rooms. You may want to post a picture of the switch box, power off, and the switch pulled from the box, wires attached. http://www.doityourself.com/forum/el...your-post.html
