Pokey: Outdoor fan
Old 04-26-12, 10:54 PM
P
Pokey: Outdoor fan
Can someone tell me the correct gauge wire to use to install a ceiling fan/light in an outdoor screen room
Old 04-26-12, 11:32 PM
ray2047's Avatar
If it is a 15 amp breaker you would use #14. If it is a a 20 amp breaker you would use #12. Are you going to use conduit or cable?
Old 04-27-12, 05:20 AM
P
I plan on just using cable as i will fish the wire through a ceiling. I can make the ckt either 15 or 20 Amp. My question is which is required, the 15 or the 20.
Old 04-27-12, 07:49 AM
pcboss's Avatar
Received 194 Upvotes on 170 Posts
A 15 amp circuit is more than enough for a ceiling paddle fan.
Do you have other power needs to the covered area?
Old 04-30-12, 08:27 PM
P
It will be a fan light combo, but it will be in a screen room that was erected under an outside deck that will have some exposure to the elements however not much.
Thank you for your reply
