Green Wire?
Old 06-22-12, 02:38 PM
L
Green Wire?
HELP.
My house was built in 1920 and I am replacing a rotary dimmer switch in the bathroom.
There three switches - regular switch operates the fan. Push rotary dimmer for one set of lights and this dimmer for the other set of lights, which works, but no longer dims the lights.
I removed the existing switch, which has a black and white wire. My new switch has two black from the same hole and a green. What do I do with the green? Or, whatever wire is going to be left out??
Thanks for your help and expertise.
Old 06-22-12, 02:49 PM
Received 1,197 Upvotes on 1,152 Posts
Welcome to the forums
Green is a ground wire and may only be used as such. How is the green attached to the switch?
Old 06-22-12, 02:52 PM
Whoops, I totally mis-read your question, sorry about that.
Normally only black (and sometimes ground) wires are hooked up to switches and represent hot/current carrying wires (though this can be a red wire as well, with -3 cable). White is normally for the neutral wire but it sounds like you may have a switch loop where the current feeds the light fixture and the hot was routed down to your switch on either of the white or black wires to then be carried back on the other when the switch is on.
Old 06-22-12, 03:58 PM
ray2047's Avatar
If there is no ground in the box the green is not attached. If BX cable is the wiring method the green should be attached to the box.
Old 06-22-12, 04:29 PM
Nashkat1's Avatar
Received 5 Upvotes on 4 Posts
Since you say the two black wires on your new switch are "from the same hole," it probably doesn't matter which of them is connected to power and which to load. Splice one of them to the white wire from the old switch and the other to the black wire from the old switch.
The green wire is a ground. It should be attached to the box if the box is metal, or to a ground wire if there is one. If the box is non-metallic and there is no ground wire visible in it, just cap the green wire with a small wire nut.
