Attic fan help please.
Old 09-06-12, 09:58 AM
A
Hello my house was built in 80s and my attic is not very big hence the fan installed there is(as I measured) 10 inches. Now 10 inch attic fans are impossible to find to replace the whole fan(I looked through the end of internet and beyond). So I was thinking of replacing the attic fan motor and I know Lowes and HD sells attic fan motors but what I dont know is Volts, Watts, RPM, size that will fit in my attic fan fixture etc. Do I just buy any motor and replace or something I need to make sure? Please help me. (is there any other information I can provide to help you help me?)
Also, before I replace the motor, is there something I can check? The fan is certainly not spinning, there is a box that connects to fan motor and that box is wired to electricity.
Old 09-06-12, 11:29 AM
Nashkat1's Avatar
Received 2 Votes on 2 Posts
Welcome to the forums!
Yes. You can use a multimeter, preferably an analog one, to check for 120V hot-to-neutral and hot-to-ground in the box where the fan connects to power. Is the fan hardwired or cord-and-plug connected. Is there a thermostat in or next to the fan?
Is this a whole-house fan or an attic exhaust fan?
All fans that will work for you will be 120V. Read the nameplate on your existing fan and look for a match to that. If you've enjoyed the way it's been working, look for the same CFM.
If this is an attic exhaust fan, a better option is to replace its function with passive attic ventilation, rather than replacing the fan.
Old 09-06-12, 11:34 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
Have you checked the breakers? Turned off then on every single pole (120 volt) 15 amp and 20 amp breaker? Do you have a test light or multimeter (no, a non-contact tester won't work).
Can you open it and tell us the wiring inside?
Old 09-06-12, 03:58 PM
A
Ray2047 - Let me open up the box and get this info in morning. Its probably oven up there right now.
Nashkat1 - It is Attic exhaust fan. Just looked at passive ventilation but it seems it is better to do it when you replace roof.
I will get more info in morning.
Old 09-06-12, 10:37 PM
Nashkat1's Avatar
Why? Why not do it now, and invest the time, energy and money you will spend replacing the attic exhaust fan toward the ventilation? Why put money into a fan that will have to be abandoned when the passive ventilation is installed?
Old 09-07-12, 06:01 AM
B
Received 37 Votes on 34 Posts
There is sometimes a service switch somewhere near the attic entrance so that power can be shut off from below.
Bud
