Fluorescent Ceiling fixture question
Received 0 Votes
We have one of those rectangular cloud fixtures on our kitchen ceiling which has 4 tubes. When we turn it on, it sometimes is very dim and then comes on in a few moments, or may not come on at all. Sometimes flicking it on and off gets it to turn on. The fixture is about 15 years old.
Does this mean that the fixture has gone bad and must be replaced? Or can it be a bulb? I didn't want to invest in bulbs if the fixture was probably bad.
Thanks!
Thanks!
Sounds like a bulb or bulbs are going bad or are loose.
These fixtures work in pairs (most of the time) so if one bulb goes out, generally so does the other one.
Should be a simple bulb replacement and go.
Easiest and cheapest is to simply replace all four bulbs with new. Another possibility is that the ballast may be going bad and need replacing. The modern electronic ballast are lighter, smaller and more energy efficient than the old magnetic ones.
I would start with the bulbs and replace all four at once - assuming they were all installed together they all then have the same number of hours on them and even if only one is bad, the rest can't be far behind.
