red wire in the light fixture, not ceiling box
Old 11-25-12, 05:48 PM
R
I'm installing a new ceiling light which has the following: 2 sets of 1 red & 2 black capped off, 2 sets of 3 whites capped off (each with two small and one thicker), a separate thin black and separate thin white, and one separate copper wire. The box in the wall only has 1 white, 1 black, and 1 copper. Can anyone help out?
Thanks so much.
Old 11-25-12, 06:26 PM
ray2047's Avatar
Received 14 Votes on 12 Posts
Do you mean connected together?
I don't understand. Are all the whites connected together? Are the small wires from a fixture. Could you please post pictures of this wiring? Was there a fixture there before? If so the only connections you need to undo are to that light and your new connection is exactly the same.
Old 11-25-12, 07:01 PM
Received 2,670 Votes on 2,422 Posts
Interesting fixture
Since the light has a single white, single black and ground - and you have the same in the junction box it should be a direct replacement.
