Half Sawn: Dim Christmas Lights
Old 12-09-12, 03:49 PM
H
Moved from: http://www.doityourself.com/forum/li...immed-out.html
I'm having a similar problem
I have 8 strings of c- 7 bulbs
one string has a bulb out that I replace with a know good bulb and wont light and the string is still dim
I have another sting with all bulbs lite but dim
any ideas before I replace them
Old 12-09-12, 04:00 PM
sgull's Avatar
Received 1 Vote on 1 Post
In my case as I mentioned I found a small melted area on the end of the faulty string (no picture available any more). I figured it must've happened because of some manufacturing defect, and returned the string of lights from where I purchased them for a refund. So that would be my suggestion if the lights were recently purchased; try to just get your money back, not worth fussing with otherwise.
Old 12-09-12, 04:46 PM
F
Received 35 Votes on 27 Posts
C-7 bulbs are 120 volt (line voltage and all the sockets are wired in parallel. If you have a problem with lights being at less than full brightness you have some serious problems with the lighting strings and they should be replaced.
