Remove an inbuilt fan, replace switch with receptacle?
Old 12-25-12, 07:47 PM
D
Once upon a time my basement had a gas grill. This was removed before I purchased the house.
I just removed the fan that was in place, and now have 2 copper wires (White/Black) sticking out. I'd like to replace the switch that connected to it with an electric socket.
I understand that the wires that used to go to the vent need to be capped and put in a new junction box. Do these need to be connected to each other for the light switch to be replaced with a receptacle?
I do not think I can get to anything behind the box housing the switch.
Old 12-25-12, 08:02 PM
pcboss's Avatar
Received 194 Upvotes on 170 Posts
Are these the wires from the switch or at the switch location?
Old 12-25-12, 08:09 PM
D
The wires from the fan are currently hanging out.
The wires at the switch are where the switch was before I removed it
As a fallback, I'm considering putting an electric outlet where the fan was, but it's not my first choice (the location is awkward)
Edit: the previous owner had pretty much mickeymoused whatever changes were made to the house. This is also true for the fan - rather than remove it, he cut the wire at the switch!
Old 12-25-12, 08:18 PM
Received 3,897 Upvotes on 3,494 Posts
If the fan wiring came directly from the switch then you should have no problem.
Right now you'll have at least two white wires connected together and the two black wires that were on the switch.
You'll need to open the white connection.
You'll end up with two white/black pairs in the switch box.
You'll need to use a voltmeter or some type of tester to find out which pair is the live feed that you will be using for your new outlet.
Cap off the other two wires.
Old 12-25-12, 08:21 PM
D
No, there are two wires coming out where the fan was, and there are two wires where the switch was. In both cases, one white and one black.
Or do you mean if I pull wires further out from the switch box?
Old 12-25-12, 08:28 PM
ray2047's Avatar
There are two wires coming out where the fan was, and there are two wires where the switch
There doesn't seem to be a set of power wires, just the remains of a switch loop. As PJ asked, do you have a multimeter?
Old 12-25-12, 08:37 PM
D
no. I don't mind trial and error, though. I'm more concerned with making sure I don't kill myself
Old 12-25-12, 08:43 PM
G
Received 2 Upvotes on 2 Posts
Wrong answer. Get to Radio Shack or Harbor freight or even a big box store and get an inexpensive analog multimeter.
The life you save and the house you don't burn down may be your own.
Old 12-26-12, 08:02 PM
Nashkat1's Avatar
Received 6 Upvotes on 5 Posts
Isn't testing and verification at the core of trial and error?
Here's one example of an inexpensive analog multimeter: Craftsman Analog Multimeter.
