wiring exhaust fan in bathroom
Old 01-06-13, 01:54 PM
W
I have a Nutone exhaust fan model QTN110E that i have installed in bathroom & went to wire up & have misplaced the diagram which tells me what the colored wires from fan go.I can run a copy of fan diagram from web site but it does not give color of wires & what wires operate what.I have pulled wire from panel box to exhaust fan & on to switch in bath room.wire coming from panel box has black,white,& ground.wires from exhaust fan
Blue & white together
Red & white together
Black & white together
One is supposed to operate a night light
One is supposed to operate 2 bulbs
One is to operate fan
Night light im not going to hook up. I have had it where light & fan would come on but would not cut off at switch & had it wired but breaker would trip.
Any help would be greatly appreciated.Also please break down so i can understand which wires go where since i am not an electrician.
Old 01-06-13, 02:28 PM
ray2047's Avatar
Did you run 3-conductor cable to the switch?
Old 01-06-13, 05:50 PM
W
wire
The wire i ran is 12/2 which has a black & white wire plus ground.I ran this wire from panel box to exhaust fan wires & from exhaust fan to switch same wire.I only want to hook up the fan & main light in exhaust fan.There is a night light to hook up but im not going to hook this up.The way i want it to work is when i flip switch light & fan will come on together.
This is whats on wire i ran---12/2 W/E Type NM-B 600 Volts
Help will be appreciated
Old 01-06-13, 06:04 PM
ray2047's Avatar
With 12-2 to the switch box you will have to put the fan and light on the same switch.
To test which wire group on the fan goes to each function connect the neutrals to power in white. Then connect each fixture hot wire one at a time to the power in black to determine which function it is.
At the fixture:
Cap the hot wire to the night light.
Connect the whites of the fixture to the white of power in.
Connect the black power in to the white* of the cable to the switch.
Connect the hot of the light and fan to the black of the switch cable.
At the switch:
Connect black and white to the switch.
Grounds connected in the usual manner.
*The white wire of the switch cable muse be remarked black, red, or any color but gray, green, or white on both ends using felt tip marker, colored tape, or paint.
Old 01-06-13, 10:22 PM
W
exhaust
I have wired every way i know how & no luck yet.The way its wired now Fan & light will run in the off position of switch but when i flip switch up to on it trips breaker also the way it is right now fan & light will run even when the the 2 wires are completely off switch.The way i have now is all whites from exhaust wired to white coming from panel box wired with white going to switch.Black wire coming from panel box wired to blue & black coming from exhaust tied in with black going to switch.I have red caped off at exhaust.Thanks for your help
Old 01-06-13, 10:53 PM
Received 3,489 Upvotes on 3,132 Posts
Ray gave you the wiring but maybe you didn't understand it.
Start with your line from the panel.
Connect the white wire of that cable to the fan's white wires. This is neutral.
Connect the black wire of that cable to the white wire going to the switch.
Connect the black wire from the switch to your fan and light hot wires (blue and black)
Sorry for the crude drawing....still perfecting my craft
In the drawing the blue wire is actually white.
Old 01-07-13, 05:34 AM
ray2047's Avatar
PJ's is more representative of your situation but here's an old crude diagram for a light that I did a while back. Just imagine both the light and fan hot at the same connection. Maybe between the two you can see your mistake.
Old 01-07-13, 05:43 AM
pcboss's Avatar
Received 168 Upvotes on 147 Posts
There is not enough space in the small junction box on the fan to allow switch loops to be used, especially if you want more than one function to work. Bring the power into the switch first. I then run a flexible conduit up to the fan housing from the switch.
Old 01-07-13, 03:54 PM
W
exhaust fan wiring
I just want everyone to know without your help i may have never got the exhaust fan wired right.I got up this morning & looked at both diagrams & reread the instructions & both basically meant the same thing but the last diagram with the instructions was more understandable for me & i had no problem with getting it to work & work right.This is not the first time i have asked for help in doing something & i would just like for you guys to know for do it yourselfers like myself Yall are great. THANKS VERY MUCH
Old 01-07-13, 05:15 PM
ray2047's Avatar
Glad we could help. Thanks for letting us know how it turned out.
