recessed lights non-IC rated
Received 0 Votes
we've had 5" recessed lights installed. They are not IC rated. The installer covered them over with existing insulation. (Prior to installation, he indicated that he was aware of insualtion issues, as he had worked on a job previously where he learned from experience the need to ventilate some recessed lights). The lights worked fine for a day or so, but two do not work now. Thinking that the old R-2 light bulbs might have burned out, I changed them. I tried them in different sockets, however, and the bulbs are good........So, what is the issue? Do we have to replace the entire recessed light fixtures, or is it a question of a burned out wire or part? Should we replace the fixtures with IC rated only? Do they make 5" IC rated recessed lights? Many thanks.
Received 0 Votes
Hey, thank you for the input on this. This is a great website and you are very kind to take the time to consider our questions.
By the way, yes, our installer knows he has to come back to "finish" the job. I suspect the problem with the lights may be related to the wiring of a couple of new receptacles he installed in the kitchen. He left saying they had been activated, but only one works. I'm guessing there's a loose wire somewhere. My inclination is to have him swap out the lights for IC rated ones of the same size.
In addition to the IC rating, many will also carry the AT (air tight) rating as well. Preventing the air leakage is important as that warm moist air not only waste energy, it can cause condensation issues.
Bud
Bud
Received 0 Votes
Any recessed lights that are installed with unconditioned space above must be air tight and insulation contact rated. It's possible the thermal protectors are tripping in the housing as the non IC cans will get very hot and shut off. Usually this causes a christmas light effect by turning off and then on again once the cans cool down. Change them out.
