hooking up ceiling fan with light fixture
Received 0 Votes
Background: I'm trying to wire a ceiling fan with 3 wires coming down from the ceiling. Two of the wires go to the wall switch that I'm assuming control the fan and light of the ceiling fan - 2 separate wall off/on switches. I know this because I went up in the attic and looked. The other wire from the ceiling is a hot wire, which I'm assuming goes to the breaker box. The multi-meter shows this to be hot when I touch it to the black and white wire. All 3 wires have a white wire and a black wire.
The ceiling fan has a white, black, and black and white wire. In what configuration should these wires be wired together?
Any help would be appreciated.
Received 0 Votes
I have 3 non-metallic cables, 2 wires each, coming through the ceiling into a box, which I'm trying to wire to a ceiling fan with a light kit. By wiring at the switch, do you mean at the light switch on the wall that turns the ceiling fan/light on? If so, there are two on/off switches on the wall, one turns on the light on the ceiling fan and the other switch turns on the ceiling fan.
With a multimeter or test light but not a non contact tester determine which cable is hot at the light.
At the ceiling:
At the switches one cable to each switch.
All grounds tied together and to the box if metal. A fan rated box must be used. If the box has mounting ears that take 8-32 machine screws it isn't fan rated.
*The whites of the switch loop cables must be recolored black or red or any color but gray or green at both ends using colored marker tape or a felt tip marker.
At the ceiling:
- Connect the black of the hot cable to the whites* of the switch loop cables.
- Connect the black of one switch loop cable to fan motor black.
- Connect the black of the other switch loop cable to the black/white of the fan light.
- Connect the white of the power cable to the white of the fan
Received 0 Votes
Thank-you for the reply. I'll try it in the morning. I really do appreciate you taking the time to help.
Kathleen
Kathleen
Received 0 Votes
Moved question to a new topic.
Previous Thread
Next Thread
