Kitchen light wiring problem!
I hope I can explain this alright. I'm adding an additional light fixture in my kitchen. Currently there are two. Fixture #1 is not part of my problem. Fixture #2 has 2 romex wires in it. One comes from the house, or power source, and the other goes over to fixture 1. Those two sets of romex were connected inside the junctin box of fixture #2, and the light was wired accordingly. To add fixture 3 I removed fixture #2 and disconnected the romex wires. I pulled out the romex that connects to fixture #1 and ran it to my new junction box at fixture #3. I then ran a new piece of romex from Junction box #2 to the new junction box#3. I connected black to black, white to white, and grounds together in both boxes. When I turned the circuit breaker back on, none of the 3 fixtures had power! Everything else on that circuit works fine. Just no power to any of the wires of the kitchen light fixtures.
What did I do wrong????
I would double check the cable that you think is the power source from the house. If it was working before it should be working now. Possibly when you made the connections the white or black wire came out of the wire nut or is not twisted tight with the other ones.
It's just a single switch that turns on both (or what would now be all 3) fixtures.
Welcome to the forums!
If fixture #2 only has two 2-conductor cables in the box for it, and one is the panel feed and the other goes to fixture #1, how is the switch wired in?
Also,
Kill the circuit, pull the switch and tell us what wires you see and how they're connected.
Also,
Originally Posted by ray2047
How is the switch wired? ... There are multiple ways to wire a switch. How it is wired can give information what the purpose of what the cables at the light do.
Thank you everyone who replied. I got it working. For some reason the switch was bad. I don't know if it something I did, or just cooincedence that it went bad during my project, but I just replaced the switch, and it all worked just fine.
Thanks agian!
Thanks agian!
