Permanent removal of recessed lighting
Received 0 Votes
Hello!
We are in the process if remodeling our master bathroom and I would like to permanently remove two recessed lights. One has already been disconnected as it was hooked up to our fan and both were on the same switch. For that one, I'm assuming that all I need to do is just remove the fixture.
The second recessed light is still connected to a switch, however. My contractor said he could remove the fixture and place a cap over the box in the ceiling, and leave the light switch that is associated with this light. I don't care if the switch stays or goes (there are 4 switches on the wall total), but I really do not want to just cap the box. I'd rather remove it completely and patch the ceiling. How can I remove it permanently?
Thanks!
Thanks!
Cables can be abandoned in place by disconnecting on both end and rendering them unusable. This is usually done by cutting as short as possible and shoving them out of the box into a wall or ceiling space. Of course if the box is removed on both ends of the cable the wall can simply be patched.
Received 0 Votes
Thank you for the reply! Is there anything special that I need to do with the white wire? My understanding is that even once I cut it from the wall switch, it'll remain hot. Should I just place a cap on it, or is there a way to permanently disconnect it so that it's no longer hot?
Thanks again!
Thanks again!
Is the switch a 3-way switch?
