switch 3 timer with 5 wires into 4 wire box
Received 0 Votes
I am trying to install a 3 switch wall timer. The timer has 5 wires -
black
white
red
blue
green
My wall only have 4 wires -
black
white
red
green
Which wire do should connect to which?
Thanks,
Jay
black
white
red
blue
green
black
white
red
green
Thanks,
Jay
Welcome to the forums.
Is that one of the new GE timers ? Which model number ?
The GE timer comes with an instruction sheet that needs to be followed as it depends how your three way circuit is wired. You may have to also go to the other switch and make wiring changes there.
Received 0 Votes
Yes, it is a GE SunSmart Digital Timer model 15312. The instructions for a 3 way only show hooking up 5 wires to 5 wires. For a single pole it shows excluding the red wire. I tried that too but it did not work.
black
white
red
green
black
white
red
green
If all you have in that junction box are the colors listed (and nothing else) then that timer will not work for you. You would need four wires and you only have three. Green/ground is not counted.
You may have to put the timer at the other end of the circuit.
