Garage Door Opener light - always remains ON
We own an old Allister Access 3000 garage door opener. All functions of the garage door, opening/closing with remote or with wall-switch etc. are being performed fine. Only issue is that the light attached to the unit remains ON all the time. If I disconnect the power from the opener - of course the light goes off. On reconnect the light remains OFF till I operate the garage. Once I open or close the garage door, the light comes on (as it should) but then never goes off thereafter. This is NOT what it used to be. Recently I had to change the light adapter on the unit and since then this problem has surfaced. Any tips on how to fix this?
*Assumes "adaptor" is a device to transfer power from the GDO light fixture to other lamp holders.
I had the same issue except I was not using an adapter. A Google search told me the circuit board function had gone bad. I replaced the opener. The board was half the cost of the opener.
