Attaching new wire to an old kitchen exhaust fan...how to ground?
Old 07-01-13, 06:21 PM
I am in the middle of a complete kitchen remodel and I am running all new wire. I have an old fasco kitchen exhaust fan from the 60s(i think) that uses a plug in fan motor. The problem is the plug was designed for ungrounded 2 wire. What would be the correct way to run new 12/2 to the box and ground it? In a lot of places in my house it appears they grounded to old boxes by wrapping the ground wire from the nm cable around the screws of the metal cable clamp...any thoughts or suggestions would be appreciated!
Old 07-01-13, 06:26 PM
Nashkat1's Avatar
Received 5 Votes on 4 Posts
Welcome to the forums!
That should work if the fan doesn't have a ground screw or lug anywhere.
Old 07-01-13, 06:28 PM
Received 2,681 Votes on 2,433 Posts
Welcome to the forums.
I would say on an old fan like that......connect the ground where ever you are able to.
I know in the past I've drilled a hole in the junction box and used a small nut and bolt.
Old 07-01-13, 06:36 PM
Thanks for the thoughts! I like the hole idea, guess ill go pick up some green ground screws with nuts to match and run it there...then see what the inspector says and will update. Love this forum, hope to help others with what i've learned doing my kitchen! Thanks again!!!
Old 07-01-13, 09:53 PM
Nashkat1's Avatar
I... guess ill go pick up some green ground screws with nuts to match and run it there...
Good lick finding 10-32 machine thread nuts. Especially lock nuts, or with lock washers. I use 1/4" hardware for this, and a green Sharpie to meet the code requirement.
Old 07-02-13, 07:59 AM
Received 1 Vote on 1 Post
What's so hard about finding a 10-32 nut? Any hardware or box store as them. Very common size.
Old 07-02-13, 12:16 PM
Nashkat1's Avatar
Maybe they've added them recently, or do things differently where you are. Used to be scarce as hens' teeth around here. Not to mention that it needs to be a lock nut, or have a lock nut under it.
Old 07-02-13, 06:16 PM
F
Received 36 Votes on 28 Posts
Old 07-02-13, 09:18 PM
Nashkat1's Avatar
Cool. Thanks. .
Old 07-03-13, 05:34 PM
Found 'em at the 'Depot...thanks for all the help!!!
