ceiling drywall thickness
Old 07-12-13, 08:57 AM
I was trying add a new connection for a ceiling fan in a top floor bed room. While checking the thickness of ceiling drywall, I found it to be one and half inch(1.5inch) or so. I thought ceiling drywall thickness will be around 5/8 inch max.
Its a cathedral ceiling.
Exparts can you please shade some light on this?
Old 07-12-13, 09:36 AM
Received 120 Votes on 107 Posts
Are you sure it's drywall and not plaster? Rare, but I have seen them double laminate the drywall before.
Old 07-12-13, 09:48 AM
How old a house is this house?
Just some guesses, may have had failing texture and someone wanted to cover it up.
Improperly insulated so they though adding another layer would help.
Old 07-12-13, 10:28 AM
96 build condo by reputed developer. It has attic about it. also has fiber glass insulation. double layer to improve insulation?
Old 07-12-13, 11:56 AM
Because it's a condo it's possible the fire marshal required the firerock to be doubled up. Most jurisdictions are cool with one layer but I have worked in areas where it was required to be doubled up with the joints staggered.
Old 07-12-13, 02:09 PM
Tolyn Ironhand's Avatar
Received 54 Votes on 47 Posts
Two layers of 5/8" drywall is considered a two hour fire wall. Since it is a condo I suspect that is why.
Old 07-12-13, 04:23 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
How do you plan to mount the box? Are there engineered I-joists above?
Does that mean the space is accessible from above?
Old 07-13-13, 07:17 AM
there engineered I-joists above...space is accessible from above
Planning to do it from below. this is the fan mount.
Cut about 8.5 inch square to put this mount.
Do you see any code violation for putting fan here?
Old 07-13-13, 07:23 AM
Nope, that should be fine.
Old 07-14-13, 07:19 AM
Thanks everyone for your help!
