Simple question obout dimmer switch install
Old 07-21-13, 03:35 PM
Micha's Avatar
Simple question about dimmer switch install
I have a dimmer switch that was originally used on a 3-way switch. I now want to install it on a single switch - is that possible or do I have to buy another dimmer?
Old 07-21-13, 03:57 PM
Received 4,148 Upvotes on 3,725 Posts
You should be able to use it as a dimmer in a single pole switch application.
You will need to determine which two are the travelers and use just one and wire nut the other one off.
Old 07-21-13, 04:49 PM
Micha's Avatar
Thanks PJ - I thought so but wanted another opinion! Wired it just as you said and it's working!
