Problem with 3 way/4 way switches
Received 0 Votes
I moved into a new house (new for us, not brand new). I am in the process of replacing outlets and some light fixtures. One issue that has me stumped is we have a switch at bottom of stairs and two up that control hallway light up. If down has been used sometimes lights cant be turned back on with switches up. Where should I start? Is this a case that i have 3 three way switches and one should be a 4th or sound more like they are just mis wired? Any suggestions would be great. Thanks.
Two 3 ways are used if something is controlled from 2 locations. Four ways are used when there more than 2 switches in addition to the 2 3 ways.
Sounds like a common is transposed with a traveler.
First identify which two switches are three ways. Those will be the ones with only three terminals and maybe a ground screw. Tell us how many 3-conductor cables (red, black, white) and how many 2-conductor cables (black, white) and how they are wired. Do you have a a multimeter? (A non contact tester won't do the job.) We will also need to know the wiring at the light.
Received 0 Votes
Guys,
I finally had time to get back to this project. The switches are as follows:
Bottom of stairs: three wires: black, red and white
Up top stairs: three wires: 2 black, one red (also some white in box in screw caps)
Up stairs hall: four wires, 2 black, 2 red
What can i check next. Thx.
John
John
It appears that the switching for your upstairs hallway light may just not be connected properly. Let's assume for the moment that the 4-way switch is wired correctly. (There should be two white wires spliced together behind it, BTW.)
Received 0 Votes
The ceiling fixture has a white and black wire. The downstairs 3 way has a red on the dark screw (black and a white on the other two) the upstairs has a black on the dark screw (black and a red on the other two). Thanks.
One of those three places should have a two conductor cable that is always hot in addition to the cables mentioned. If there is only a single two conductor cable at the light then the most likely scenario is both a two conductor cable and a three conductor cable at each three way switch. If not describe in detail all cables and their wires at the four way switch.
