3 bulb fixture , only 2 bulbs work
Old 08-19-13, 10:07 AM
I have replaced a single bulb fixture and succesfully installed a switch. I have replaced the existing fixture with a 3 bulb fixture and only 2 bulbs light up. Im wondering what the problem is ?
I know its not the fixture because this is the second fixture.
Thanks in advance
Old 08-19-13, 10:45 AM
ray2047's Avatar
Swap bulbs between sockets. Slightly bend up the tab at the bottom of the non working socket. Redo your connections. If the fixture had three blacks or three whites it sounds like one of those isn't making a connection where it is connected to the house wiring. Many new fixtures come with "fake" wire nuts that contain no spring inside. If that is true replace with "real" wire nuts.
Old 08-19-13, 11:25 AM
Thanks. I fugured out the problem. one wire was disconnected when I attached the fixture
Old 08-19-13, 11:43 AM
ray2047's Avatar
Glad you got it. Thanks for letting us know.
