ceiling fan / ceiling light problem
Old 08-31-13, 04:08 AM
V
I have 2 recessed ceiling flourescent lights at opposite ends of the kitchen...In the center is a ceiling fan....
Since installing a new kitchen floor and countertop, the fan rotation is bouncing off the lights like a 'strobe' light onto the walls and appliances...
Any / ALL suggestions for a remedy will be greatly appreciated.....Thank you
Old 08-31-13, 04:18 AM
pcboss's Avatar
Received 163 Upvotes on 142 Posts
Pretty much only two options. Move the lights away from the fan or ditch the fan. This should have been considered in the planning process.
Old 08-31-13, 04:28 AM
V
Since the lights and the fan have been in place long before the new floor and counter (and without any problem), it never occured to me (in my planning process) that this would be an issue...
I did invest in smaller fan paddles hoping that would resolve....But, it didn't.....
You've confirmed my only option now is to move the lights---since removing the fan is not an option..Thanx for your input....
Old 08-31-13, 04:45 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
How far from the fan blades are the lights located? You may want to try one of the compact gossamer type blade fans. They move a bunch of air, but are not as large as normal, nor are they elegant by any means. As a googled example: Monte Carlo Fans Compact 20-Inch Ceiling Fan with Four Blades | 4MC20RB | Destination Lighting
Old 08-31-13, 04:51 AM
V
Hi Chandler....thank you for your suggestion.....
The original fan blades did overlap the lights....The new ones extend to the frame of the lights....I was really hoping reducing the size of the blades would do it...
I'll check out your suggestion of that Monte Carlo.....thanx again....
Old 08-31-13, 04:58 AM
chandler's Avatar
I had a friend who was subject to seizures, and had a similar situation with a new fan overlapping his LED lights. Whoa!! Had to change that one out real quick!!
Old 09-02-13, 06:10 AM
R
So.... what about just painting the fan blades with a dark flat paint?
Event batter, one that is flat and slightly textured. That will eliminate the possibility of reflection.
I am assuming your problem is light bouncing off the floor/countertops and onto the fan blades.
If it is that the fan blades "overlap" the downlight pattern, and this is a shadow effect - consider installing some short soffits between the light and fan that creates a blocking shadow that is constant whether the fan is moving or not.
Old 09-02-13, 07:36 AM
Nashkat1's Avatar
Received 5 Upvotes on 4 Posts
One challenge with painting fan blades is they will throw the fan off balance if the weights are not kept close together. It's doable, but you have to spray each blade lightly and with the same amount of paint.
Old 09-02-13, 08:09 AM
pcboss's Avatar
I think the issue is the strobing effect of the blades rotating through the cone of light from the recessed.
