solar controlled lights
Old 09-05-13, 07:44 AM
H
Hello.
I have two coach lights on my garage. Each fixture has two candelabra sockets that take a max of 60 watts each. I've recently added solar controlled sockets to turn the fixtures on and off. Unfortunately, only one of the bulbs in each fixture lights when it gets dark. I've checked the bulbs without the adapters in the sockets and they all work fine. The socket adapters are brand new. I have no idea what could be causing this to happen.
Thanks
Old 09-05-13, 08:15 AM
ray2047's Avatar
Received 14 Votes on 12 Posts
Are the bulbs incandescent?
Old 09-05-13, 08:17 AM
G
Received 2 Votes on 2 Posts
If you have a sensor on each socket, I suspect that when one turns it's light on, the second sensor "sees" the light from the first bulb and, thinking that it is daylight, does not turn on the second bulb.
Adjusting the position of the sensors may help.
Old 09-05-13, 08:41 AM
H
Thanks for the quick responses. Yes they are incandescent bulbs. No I haven't tried positioning the sensors. I'll give it a try. I'll check back in if that doesn't do it.
