Ceiling Fan Wiring
Received 0 Votes
Ceiling Fan Wiring
I've looked through some old posts to see if anyone had the same issue as I did and while there was plenty of ceiling fan wiring threads, none of them fit my particular situation.
So I recently replaced an old ceiling fan with a brand new one. Now the fan works fine but when I turn the light switch on, the lights turn on for a second but then shut right off. When I took the old fan down, there was a black, white and ground coming from the ceiling. I attached the black and blue from the fan/light to the black from the ceiling and then attached white to white and ground to ground.
The fan/light is connected to a single switch. In the switch box there was two whites taped together, 2 blacks, one attached to each screw of the switch, and a ground.
I can't figure out what might be causing the lights to shut off immediately. Any suggestions?
It seems your wiring is correct, albeit possibly loose. Have you pulled the bell down and resecured all the black/blue wires and the white wires? Check your bulbs to make sure they are seated securely in the sockets.
Received 0 Votes
Bulbs have been checked and they are securely seated. I've checked the wiring and everything seems to be connected pretty tightly both in the fan and in the switch box. But still every time I flip the switch, the lights turn on and then right off. Don't know where to go from here.
Moving on to the problem:
I attached the black and blue from the fan/light to the black from the ceiling and then attached white to white and ground to ground... Bulbs have been checked and they are securely seated. I've checked the wiring and everything seems to be connected pretty tightly both in the fan and in the switch box. But still every time I flip the switch, the lights turn on and then right off.
Since the fan is working properly, the neutral and the black wire appear to be connected properly. Check the connections for the blue wire in two locations:
In the canopy, take the power splice apart. Make sure that there is an adequate amount of conductor exposed at the end of the blue wire. Lay the black house wire, the black fan wire and the blue fan wire together with the ends of their insulation lined up. Twist those three wires together gently, clockwise. Twist a new wire nut with a good steel spring coil inside it onto the splice to complete and protect it.
In the hub, make sure that the push connector that connects the wires for the light kit to the wires feeding down from the canopy is solidly and securely connected.
One question: Is the wall switch an on/off switch?
Received 0 Votes
I've replaced the duct tape with a wire nut since I had the outlet taken apart. I checked all the wires, even took the whole fan down and started everything from the beginning. Still no luck. And yes the wall switch is your standard on/off switch.
The only remaining test I can think of is to dismount the light kit, cut the switch on, and test for 120V at the light kit connector. Kinda tricky with the fan running though.
Received 0 Votes
Ha...By duct tape I meant electrical tape. Yes the lights are still coming on for a second and then shutting off. It has a pull chain, when it's pulled, the light doesn't turn on at all when flipping the switch so the chain is working. I am just using the 40 watt bulbs that came with the ceiling fan. I have not tried using them in any other fixture.
