Installing a light fixture- need a little help before I burn down the house
Received 0 Votes
Hi everyone, I recently bought a house (built in 1901) in Brooklyn NY. The light fixture in the entrance hallway is ugly as sin, so this past weekend the wife and I bought a new one. I figured it would take an hour or two to swap the old fixture for the new one. Here I am 5 days later still trying to figure it out.
The hallway light that I’m replacing is controlled by a single switch. I’m replacing a hanging fixture with 4 bulbs to a hanging fixture with 1 bulb. When I removed the old fixture I was greeted by a nice tangled mess of old cloth-covered wires, in an old junction box unlike one I'd ever seen. I expected to see maybe three wires in the junction box, instead I've got 7. I used a non-contact tester and from what I see there were 3 hot wires grouped together in a wire nut (not connected to the old fixture, and not affected by the light switch on the wall); there were three neutral wires grouped together in a separate wire nut (connected to the neutral wire of the old fixture), and there was one more hot wire attached to the fixture's hot wire (this one is turned on/off by the switch on the way). Nothing is color coded as this is old wire. Also there is no ground wire. The old fixture did have a bare copper wire running down its chain, but I don’t believe it was attached to anything in the junction box. FYI the new fixture doesn’t have a ground wire at all.
The new fixture wouldn’t fit onto the old junction box due to the shape and being no place to attach a cross bar, so step 1 was to remove the old junction and replace with a new one. Due to the space available I had to use a 1/2" deep “pancake” junction box. I replaced the box, and reconnected the wires as they had been. I tested again with a non-contact tester, and again everything seemed fine. One of the hot leads only shows current when I turn the switch on, the other three hot leads always show current even when the switch is off, and the remaining three wires show no current at all. I then used a circuit tester- when I touch the junction box with the tester’s negative wire and touch a hot wire with the positive, the tester shows me 120V. The same happens if I touch the hot and neutral wires.
I then attached the fixture. The neutral went to neutral and the hot went to hot. I even double-checked these with a continuity test- the hot wire is connected to where the light bulb’s tip will be, and the neutral is where the outside threading of the bulb will be.
When I turned on the light it doesn’t work. MORE IMPORTANTLY when I put the non-contact tester next to the fixture itself it lit up and beeped. So unless I’m going crazy there is actually currently going through the metal OUTSIDE of the fixture, i.e. the decorative canopy covering the light. I’m not seeing current in the chain from which the fixture is hanging. I immediately shut off power again at the breaker box, removed the fixture, and checked connections. Again everything seems OK. I’m not seeing a short (using a continuity test) between the hot wires and the junction box, or between the hot/netural wires, etc. Not really sure what to do from here. Can the fixture itself be broken?
Any help or insight is appreciated.
Received 0 Votes
Sitting here at work waiting for someone (ANYONE!) to respond
and something just occurred to me that may be involved.
Like I said there were 7 wires in the junction box. Why the odd number? I'm remember now being confused about this. There were basically 3 metal-armored cables running to the junction box (AC/BX cable). Two of the cables had two wires inside. The other had 3 wires. So I think I messed up. The two BX cables with two wires are clearly hot & neutral. But I'm guessing the one with three wires is hot/neutral/ground. Does this sound right?
I treated ALL wires without a current (as detected by the non-contact tester) to be neutral. I therefore connected them all together in a wire nut to the neutral wire on the light fixture. If I'm correct though, then I ended up connecting that one ground wire, which I'm reading is a big no-no.
If it sounds to you like I'm on the right path to an answer...how do I determine (in the BX cable with 3 wires) which of the three is neutral and which is ground? And where would I attach the ground wire, because there is no bare copper wire in the new fixture. Would I attach it to the ground screw on the junction box?
Unfortunately there are no colors on any of the wires.
At the 3-conductor cable using a multimeter measure between each wire and ground (the metal box) with the switch off. The one that shows 120 volts switch off label black. Test the other two with the switch on. If one is hot with switch on mark it as red. The third wire should be white your neutral. Finding which is black and white on the other two wires will require determining where they go.
However the big problem which must be fixed first is you can only have two house wires and two fixture wires in a pancake box.
